8000 electrical relay
Josh(NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh(NE) Quote  Post ReplyReply Direct Link To This Post Topic: 8000 electrical relay
    Posted: 06 Jun 2017 at 11:10pm
Shame on me for not having a manual yet. I just ordered it tonight from jensales. In my new to me 8030 the two 30 amp relays under the dash are strapped together in a very factory looking manner in parallel as to create a 60 amp over current device.  There are a pair of 12 gauge, one 16 gauge, an 8, and a 6 gauge wires all strapped down here all in the factory harness, this doesn't look right to me although all of the wires are factory. I was looking to use one 30 amp relay to power my baler monitor, but I need help making since of what I have here. My manual is on the way, but I need to get this set up. Thanks
Allis Express
'65 190XT, 37 B, '72 170, '83 8030, and the IH 560 was a mistake
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2017 at 9:37am
I'd need to see the wiring diagram. Personally I'd rather drive a fuse block with one larger relay. I'm also curious of how they terminate one large #6 wire onto the relatively smaller 30 amp relay terminals. I suspect that the two relays aren't paralleled per se, but are two relays with a common feed and separate outputs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh(NE) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2017 at 12:45pm
Allis Express
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh(NE) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2017 at 8:46pm
Originally posted by Josh(NE) Josh(NE) wrote:
So the top wire with the big end is the 12 volt source through the firewall. The 3wires under it feed the fuse block and the second biggest wire below feeds the ignition switch. This cannot be the proper placement and strapping for the relays.
Allis Express
wekracer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2017 at 7:14am
Well first I will say that those aren't relays they are breakers. Next I would ask what is wrong with that setup. All 3 of my 8000 tractors are that way.
To run your baler monitor just land on one of the terminals on the line side of the breakers. If you don't have an inline fuse on the supply for the monitor I would put one in. That's how I run my planter monitor and air ride seat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh(NE) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2017 at 8:29am
Yes breakers, not relays. Okay glad to know there is no issue here. It just appeared odd to parallel two overcurrent devices.  Thanks so much.
Edited by Josh(NE) - 08 Jun 2017 at 8:32am
Allis Express
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2017 at 8:35am
Obviously, that junction is for constant Battery feed power. You could go off the left side below the other lead on that junction to take Battery power to run your monitor. As Racer mentioned, fuse or install a circuit breaker accordingly (find out how many amps the monitor uses to determine fuse size) run it through a high amp switch (or toggle switch if less than 10 amps) to power your monitor so the line and monitor are protected. You should be good ta' go....
Steve@B&B
This page was generated in 0.043 seconds.
