78 Planter Unit Question
Michael (WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael (WI) Quote  Post ReplyReply Direct Link To This Post Topic: 78 Planter Unit Question
    Posted: 03 Jun 2017 at 9:56am
While servicing my 330 planter with individual unit drives for storage I noticed that the press wheel on one row turned very very stiffly.  I should note the 78 planter units have insecticide hoppers only.  After disconnection the drive chain to the seed disc I determined it was the insecticide hopper drive causing the issue.  I took the insecticide drive (housing & bushing/bearing) out of the frame and I could not rotate the drive by hand.  With a little BP blaster and a drift I was able to get the busing out of the housing and clean them up.  Question is when I put it back together what if  any lubricant  should I use??  Grease, heavy oil, light oil or nothing at all?  I don't want to use the wrong product, have it attract dust and seize up again in the near future.  If anyone wants to look up a sketch it is numbers 3 & 4 under the "Drives, Insecticide Dive, Herbicide Drive"
 Thanks for the help.
Edited by Michael (WI) - 03 Jun 2017 at 9:59am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael (WI) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2017 at 1:24am
Bump.
