7030 pto slips inder load
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Topic: 7030 pto slips inder load
    Posted: 01 Jun 2017 at 9:37am
I may go look at this 7030, seller says pto stopped working so he checked pressure in the line, no pressure. He said he has changed all 3 pumps, still no pressure to pto. He says power steering and 3pt work but pto still slips under load. At this point he just wants it gone. Could this be something as simple as linkage or could the clutch plates be bad, stuck valve? Guy says the rest of the tractor is tip-top shape. I haven't actually seen it yet, just wondering what to look for if I do.
Thanks
Leon B Mo
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2017 at 11:41am
Does the PTO lever stay fully forward in the engaged position ??   If he has no pressure at the clutch (like he says) the PTO will want to crawl but never pull a load. Sounds like a hydraulic oil supply issue. Might be a tube blown out of the PTO valve into the rear end housing ??  Not sure his story is accurate. Replaced all THREE pumps and the PTO still has no pressure??? Obviously he's throwing darts at a dart board hoping one will stick in the right place !!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2017 at 12:00pm
I don't know if the lever stays forward or not. I remember a topic on here about a bent bracket causing a pto problem but don't remember the circumstance. May have to go see for myself.
Thanks.
Leon B Mo
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2017 at 10:37pm
could be torque limiter as well????
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2017 at 7:31am
Ad has been deleted, so I guess I don't need to worry about now.
Leon B Mo
