looking for flotation front tires - WD45`
sploke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sploke Quote  Post ReplyReply Direct Link To This Post Topic: looking for flotation front tires - WD45`
    Posted: 01 Jun 2017 at 7:35am
Hey everyone,
I have a WD45 with a front end loader.  The front wheels are stock (4.25x16" I believe?) and the tires are the standard narrow-profile tri-rib design, which really tend to dig in and rut when the bucket is full.  I'm looking to change them over to a wider, flatter flotation design for easier steering and less rutting when working with the tractor.  Two questions - is there anything available that would work on the stock 4.25" rim?  If not, does anyone know the stock bolt pattern so I can look for a replacement wider rim/tire combo?  Thanks!
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2017 at 8:26am
In the 1950's Buick had a rim that would bolt on to the 45's.  Was 15" and wider than stock.  Guys put 7.5LX15 3 ribs on them.  Helped some.  If memory serves me right was about the widest rim you could use unless you took a 8 or 10" rim to the local welding shop and had them move the center.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2017 at 8:56am
 Tom is correct.I have  Buick rims form early 70's but had to trim center hole just a little to fit.Tire is close to spindle.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2017 at 9:03am
theres one thing to think about, those stock tires and wheels dont carry enought weight to bust up the rest of the tractor front end . i have thoudht of making some eight inch wheels for mine myself  but i have allready broke a spindle lifting around the shop
Post Options Post Options   Thanks (0) Thanks(0)   Quote sploke Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2017 at 9:36am
Good point.
How wide a tire could I reasonably get on the stock rim?  I see a 7.5" tire that might work, but it recommends a 5.5-6" rim.  If I squeezed it onto the stock rim, would it work other than maybe being squeezed into a rounder shape than intended?
orangeman69 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman69 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2017 at 9:54pm
google Hay Tire and wheal I got wider rims for my 17 from them. I put 7.5L-15s on it. if you don't see what you want call them they will make them up.
d17,d17nfpuller,d-17IVdiesel,d19gas,d19diesel nf,d21seriesII,180,190xtseries III,200,210,7020,7060,7080w/8.3cummins,8070fwa w/8.3cummins,8550 185 w/322 original hrs.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2017 at 9:51am
Something like this? It's too bad we are so far apart, I would sell them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote sploke Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2017 at 10:02am
Yeah Mike that's pretty much exactly what I'm looking for.  I wonder if I could get these guys on there:
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2017 at 10:12am
Not sure if they will work or not. Also I don't know what these rims came off of, they are not AC. I have a pair of 7.5L 15s that are going on this tractor if I ever get time to do the 6 bolt hub project.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2017 at 3:32pm
IBWDMike
what are you asking for those wheels and tires?
Thanks
Another Mike
45 turboa- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 45 turboa- Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2017 at 3:59pm
I put 9.5l 15s 4 rib tractor fronts on my WD45  I cut the centers out of some old stock rims and welded them into some 8in wide rims. works good !
turbocharged
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2017 at 8:40am
IBWDMike
Thanks
Another Mike[/QUOTE]
I'm not sure, need time to get the 6 bolt hubs/tri-ribs on before I can sell these.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2017 at 10:02am
IBWDMike
Thanks
Another Mike
[/QUOTE]
Ok, I am interested
Thanks
Mike
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2017 at 8:32am
I'll keep you in mind Mike. Beans are finally in the ground and starting to make progress on other things.
boggen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote boggen Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2017 at 4:05am
google "agriculture tires" and find the manufactures, then do a dealer lookup,  do this to a 2 to 4 manufactures to find your local dealers.  give the dealers a call up with your rim dimensions,  they most likely be able to find you a tire that will work and different tread design.
i am on the opposite side of things. with allis chalmers CA tractor. with narrow front end wheels. i need the 3 ribbed tires. so i can actually turn while in any sort of mud, or dirt, or even snow, heck even mowing the lawn.   originally had nearly balled 3 ribbed tires, and the front would just keep on pushing forward and never turn me.
granted no FEL (front end loader), but this is still wet time of year,  if you are getting ruts, wait till it drys out more.
