D14 loader value |
Post Reply ![]() |
Frankenpez ![]() Bronze Level ![]() ![]() Joined: 16 Oct 2014 Location: NE Points: 11 |
![]() ![]() ![]() ![]() ![]() Posted: 30 May 2017 at 10:40pm |
Hello, I'm looking at a D14 with an Allied 6' loader. Not wanting the loader, could someone give me an idea on the value of the loader? I'd like to sell it seperately should I buy the tractor. Then I can make an appropriate offer on the tractor.
Thanks in advance- Jon |
dt1050 ![]() Orange Level ![]() Joined: 05 Jul 2011 Location: central pa Points: 1078 |
Hi jon, were gonna need to know what kinda shape the loader is in and photo's help a lot. dt
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24618 |
Maybe $500-$1000 depending on shape and leaks,assuming the front pump/bracket,hoses, frame ,etc. goes as a complete package.
I took off the 6' bucket on 'Milton' as it's too big for my use. Does the D-14 have power steering ? It should when using a loader.... Check BOTH front rims real careful. Milton needed new ones as both had stress fractures near the bolt holes. I'm thinking a lot of turning while stopped with full loads caused them. If the clutch pedal 'diamonds' are wore, it was used a LOT for loader operation, so maybe new clutch/bearings will be needed. Jay |
https://siouxcity.craigslist.org/grd/6152599642.html
Craigslist Hopefully this link works. Ideally I'd like to be in the tractor itself for $1500. At least thats my budget. Not sure if the loader is worth around $1000? As you can see there's no pictures of the bucket unfortunately. Thanks again for the help and opinions of this tractor. |
Post Reply ![]() |
