OC JD 7000 Planter Question
ibleedorange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ibleedorange Quote  Post ReplyReply Direct Link To This Post Topic: OC JD 7000 Planter Question
    Posted: 30 May 2017 at 4:39pm
My neighbor has a JD 7000 4 row planter. She plants about 80 acres of sweet corn every year. Her lead man told her that about half the seed is getting crushed or cracked. Anybody any experience like this? I put in new augers from Shoup a couple years ago. Thanks ahead of time for any insight you could provide.
Tractors; If it runs, use it. Motorcycles: Ride em like today is your last day.
bobkyllo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bobkyllo Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2017 at 5:14pm
New augers for what? That planter should not be crushing the seed. I'm not totally familiar with the junk Deere but I don't think you have to change any settings when you switch seed size.
bakwoodsfarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bakwoodsfarm Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2017 at 5:27pm
The  only augers are in the fertilizer bins, it has a belt metering system, I don't see how it can crush seed at all.
Daehler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daehler Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2017 at 5:50pm
If the meters havent been tested, they need to be. Something could be broke or out of time. We have our finger meters ran every year to make sure singulation is up to par and to make sure there are no broken parts. It is posible that when the finger comes around and grabs a kernel it could crack it especially if there is to much tension on the spring, Sweet corn seed is a little different than field corn. By the way 80 acres is a lot of sweet corn!!
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2017 at 8:44pm
Put it on the test stand. But I doubt it's the meters. We planted a chunk without issues. We could even plant sunflowers without issues.
Wayne180d View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wayne180d Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2017 at 8:49pm
I planted with a 7000 for five years and never had an issue with crushing or cracking the seed.  I wanted a IH Cyclo but this one came available and was priced right for a Deere in our area and was very happy with it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2017 at 2:36am
some 7000's were finger fed, and some used the old style planter plates, which is that one?
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2017 at 6:21am
Exactly what Shameless said, finger pickup or plate style meter?  I'd think if plates and your plates are too big, you could be crushing some seed.  I don't know about "half", that would be terrible, but it could happen I suppose if the cell size was way off.
"Belt metering system"?  I have no idea what this means.  Nothing like that on a 7000.
old farmer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote old farmer Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2017 at 6:58am
Deere uses a belt to get seed from finger pickup to discharge point at ground level.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2017 at 7:05am
Yeah, but that's hardly the metering system.
This page was generated in 0.957 seconds.
