7060 Powershift issue
AC 426 power View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC 426 power Quote  Post ReplyReply Direct Link To This Post Topic: 7060 Powershift issue
    Posted: 29 May 2017 at 5:19pm
Got a moron belly 7060 with a powershift and today while pulling a a JD 220 disk the tractor would not move in 1st gear high range. I was pulling into the field for the first time after about a 13 mile trip on the road and was unfolding the disk when I noticed it. Had foot on clutch and released it and it would inch forward a bit and stop. Put it into second and it moved fine. Power shifted it back in 1st and it moved as normal. Stopped tractor and put it in 2nd again and back to first and it took off as normal in first gear. Oil level is normal, the only other thing I have noticed is the floor broad seems to be warmer this planting season then I can remember, can feel my feet getting warmer. Any ideas?
rw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rw Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2017 at 8:42pm
some times the shifter kind of lands between two gears and you get no movement.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2017 at 9:31pm
If shifter don't feel normal shifting between gears, the spring or linkage could have broken on inside of valve body.   MACK
