Blanket over AC on 7000
Tim NH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim NH Quote  Post ReplyReply Direct Link To This Post Topic: Blanket over AC on 7000
    Posted: 29 May 2017 at 7:36am
My after market operators manual shows a blanket that goes over the evaporator. What have you guys used, and how tight around it do you make it.  Thanks Tim
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2017 at 8:25am
Foam to cover area between fan and evaporator. MACK
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2017 at 12:10pm
I found some foam at wally world that was 1" thick, worked great. the foam will be in the sewing/hobby section, that's where I found it.  ya gots to have a seal there so the air flow works right
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim NH Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2017 at 4:37pm
I'll get some there. Thank you both for your replies.  Tim
