190 lift arms
acplowboy45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acplowboy45 Quote  Post ReplyReply Direct Link To This Post Topic: 190 lift arms
    Posted: 26 May 2017 at 4:38pm
Having problems with the lift arms staying up...just recently pulled the hydraulic remotes out and replaced one of the units...I know there is a screw on top of the units to set lift arm controls. Is there something else I'm not doing to get the arms to stay up.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2017 at 9:47pm
check the traction booster linkage
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2017 at 10:28pm
Fit of spool to body is all that keeps arms up. A loose fit will let arms down quicker than a good fit spool.
I was told years ago by a AC service man when I ask the same question (the system is a lifting device not a holding device).    MACK
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2017 at 10:36pm
some early units had a rate of lower screw, the other screw is a high volume bleed of screw that is a draft assist. As Mack sez neither has anything to do with light arms staying up - You either have a cracked 3 pt valve, a pitted spool or leaky / line/cylinder. IF no leaks, you have two choiced - replace the 3 pt valve or use the position control to keep them up.
