Allis C Engine - Getting Water in Oil
gdtractor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gdtractor Quote  Post ReplyReply Direct Link To This Post Topic: Allis C Engine - Getting Water in Oil
    Posted: 24 May 2017 at 1:07am
Hi ..  I am still getting water in oil with a new head gasket ..
I know in this video ... I should have NEVER hit the sleeve with a hammer ..  it seemed to be okay ..
What I am wondering ..  do the sleeves have rubber O rings/ I put a new head gasket on?  Do the sleeve O rings have anyting to do with coolant/water? https://youtu.be/raf0Z6DzAXU
Above is a video of the block ..  or perhaps the head is warped
thanks
Gary
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2017 at 4:09am
Or a sleeve seal is leaking.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2017 at 6:33am
Once an old sleeve moves the bottom O rings will leak. You can hope with all your heart and they will still leak. I do not know how long it takes however they get hard and will not expand to reseal once the seal is broken after a time. Hitting with a hammer is a no,no but I doubt it caused any damage. The damage causing your leak happened when the sleeve moved.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2017 at 8:07am
put washer on bolt and clamp liners before turning engine
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2017 at 8:15am
So many guess about these leaks and there is no reason for it.  Remove the valve cover and oil pan and look for the leak and then fix it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2017 at 8:26am
Watch his video Butch! That kinda takes the guesses out. I don't remember for sure if the core plug leaks were covered on his earlier posts when he had the head removed but I think it was.
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2017 at 9:37am
it seemed to be okay is guess work
nonetheless ,still dead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2017 at 10:06am
After hitting a sleeve a leaking o ring would likely be the culprit. And it ain't going to fix itself. Listen to Dick L, Fred and Butch;
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2017 at 11:28am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2017 at 4:43pm
I cringed when I saw that sleeve come popping up.
That hammer is a NO-NO...........you're lucky you didn't split it.
Take a look at Dick's head, with NEW freeze plugs......probably will solve your problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gdtractor Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2017 at 11:22pm
THX MUCH !!!!Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote gdtractor Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2017 at 11:23pm
THX MUCH >>  I APPRECIATE IT!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote gdtractor Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2017 at 11:26pm
THX DICK !!!!
