7045 Lift Arm Control
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Topic: 7045 Lift Arm Control
    Posted: 23 May 2017 at 6:46am
Got something way out of adjustment or loosened up ( or broken ).
If you pull back on the lift arm lever (all the way raised), it will slowly work forward lowering the arms.  It gets to a point, and then lowers very quickly, like the weight is pulling it down.  If you put a load on it (plowing), it feels like it actually fights you wanting to pull itself all the way down.  I had to physically hold it in position or it would suck all the way down.  Fun to do while having to fart around with the tail wheel at the same time!  It behaves this way regardless of traction booster set at 1 or 6.
What am I looking at here?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2017 at 7:16am
Probably the friction device on the 3-point lever needs to be adjusted or may have something wrong with it. If you remove the top of the console and look, you'll see a spring loaded device that has a friction pad (like a disc brake) on it. When you pull rearward on the lever, it flexes and has zero drag. When the lever is not being pulled to the rear it sets up and holds the lever in one spot. Take a look. Might just need to tighten the adjusting nut a little. This is where I'd start. You still might have linkage behind the cab that is rusted and causing the problem, but start with the lever.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2017 at 7:21am
Thanks Doc.  I'll take a look.  I don't think it's rust as I've been using it for a few days "normally" before this began to happen, so something loosening up sounds likely.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2017 at 8:24am
The shaft screws in and out in order to adjust the one way brake.   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2017 at 10:08am
The friction device was the culprit.  Thanks guys, that was an easy one.
This page was generated in 5.938 seconds.
