7010 decal placement
rmullican View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rmullican Quote  Post ReplyReply Direct Link To This Post Topic: 7010 decal placement
    Posted: 22 May 2017 at 10:24am
Does anyone have a pic for factory placement of gear/speed chart on 7010 PD. Book states right column. Thanks for any help.
170 W/FEL, 7010 PD, 8030 FWA PS
Roscoe62 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roscoe62 Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2017 at 7:38am
This is one that I made from the book, should be exactly the same:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roscoe62 Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2017 at 7:41am
And another copy, sorted this time by the "speed" column:
- Roscoe
Post Options Post Options   Thanks (0) Thanks(0)   Quote rmullican Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2017 at 8:49am
Thanks for the info, but I was wanting to know where the factory decal mounted (above or below console light)
LB0442 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LB0442 Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2017 at 9:16am
This is a scan from a brochure.  I had to check the ones I have and the parts units are gone and I took the foam out of 2 of the ones I am using to clean up the cab.  It shows the location in the scan, above the light, but the decal is incorrect, possibly a pre production one.  I had some decals made for my patterned off the originals.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rmullican Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2017 at 8:28am
Thanks for the pic, showed me what I needed to know
