Urgent help needed
blue924.9 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote blue924.9 Quote  Post ReplyReply Direct Link To This Post Topic: Urgent help needed
    Posted: 20 May 2017 at 9:31am
Hey guys getting my wd pulling tractor back together and am getting the top end wrapped up. I'm wondering what I need to set the valves at cold for the first start. I know it needs to be set for the final time hot but wondering what cold spec should be. Also does hot. 010 intake and .019 exhaust sound right? Thanks.
hi my names dan, I am a young guy. i have a problem, i prefer my tractors orange and my clutches mechanical, thanks for letting me share
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2017 at 9:58am
I'd go for at least .015 maybe .025 cold on the intake because usually the clearance is less with the engine hot and you don't want new valves held open to leak and burn the valve and the valve seat. The bigger the gap the more delay in the valve opening but an intake valve leaking combustion pressure upsets the whole engine running.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2017 at 12:26pm
.015" COLD for intake and exhaust.
Post Options Post Options   Thanks (0) Thanks(0)   Quote blue924.9 Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2017 at 9:43pm
Dr does that need to be changed after it's hot or is that the cold spec
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2017 at 8:48am
.015" COLD and you are done.
