A.c. 190
showcattle75 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote showcattle75 Quote  Post ReplyReply Direct Link To This Post Topic: A.c. 190
    Posted: 19 May 2017 at 1:33pm
Changing final drive oil on my 190 I have 75w 90 would that work for the final drive and how many quarts does it take ?
mintenfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mintenfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2017 at 2:56pm
I don't think 190s had final drives.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2017 at 3:09pm
they do just inboard,  but oil is separate from trans and rear end.  yes that will work
Beirnesy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Beirnesy Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2017 at 6:21pm
75 w 90 is quite often a synthetic blend or a full synthetic oil,  is that the case here?  Myself I would not use synthetics in the transmission or final drives of  these old tractors with 30 or 40 year old seals still in them for fear of the oil migrating past seals into compartments where is shouldn't be. If it was a fresh  rebuild with new seals I would look at it differently.  And I use synthetics, but I pick my spots,  and have worked in the fuel and  lubricant business for 30 years.
Edited by Beirnesy - 19 May 2017 at 8:43pm
1969 220,1967 190DXT,1968 190DXT, LGT's 710,,716
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2017 at 6:38pm
The issues of synthetics causing seals to leak was corrected over 30 years ago.
Post Options Post Options   Thanks (0) Thanks(0)   Quote showcattle75 Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2017 at 7:10pm
So yes I can use 75 90 ?
