d17 let me down
acd21man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd21man Quote  Post ReplyReply Direct Link To This Post Topic: d17 let me down
    Posted: 17 May 2017 at 8:16pm
well i bought a hoelscher 1000 accumulator and i was planning on running it with the d17 yesterday and plumed hydraulic and nothing but disaster all day. we thought valves was stuck and i moved about everything i could. well i learned about open and closed center systems and we move some hoses and settings  no change go and get a deere and things works perfect lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd21man Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2017 at 8:26pm
and thats no joke. we worked all day and nothin it was awfull the 17 was getting in a load bad a times and you could move the table tilt lever and the arm that slings the hay up would come up or the arm lever and the table would go up or sometimes the arm would shoot up. there is 2 setting for open and closed systems hooked the 4430 to it and like a new machine really kinda mad about all this but its ok
then comes the adjustments for the size bale lol but its working good now
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2017 at 9:12pm
Well, you tried. Sure would have been a lot cheaper to run the D17.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2017 at 9:29pm
That's the thing with trying to adapt older tractors to newer stuff, gets aggravating fast, especially when it's Go time,, that JD Prolly done a good job
EPALLIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EPALLIS Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2017 at 9:47pm
Yup.  D-17 needs to be hooked up to implements of that time period.  You take your chances on a 50 year old tractor on an implement produced 5 years ago.  If it works great, but don't count on it.
cottonpatch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cottonpatch Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2017 at 10:11pm
The exact reason I avoided that unit and went with a kuhns accumulator. I took delivery of a kuhns 1036f yesterday and put it behind my D17 III diesel. Flawless dropping six hundred squares on the ground today. It was also $2k cheaper.
'52 CA, '61 D10 II, ‘61 D15, '66 D15II, '63 D17D III, ‘69 170, '73 185 Crop Hustler, '79 185, '79 7000, '77 7040
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2017 at 7:57am
A friend of my Dad bought a new Deere planter this year and could not make it work correctly on his New Holland tractor that is only a few years old. Ended up trading the New Holland for a new Deere tractor. So it isn't only the old tractors that won't work with newer equipment. Seems the Deere planter isn't very compatible with New Holland.
Wink
I am a Russian Bot
Dan73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2017 at 7:30pm
What to you have for hydraulics on the d17? I have a d17 serries 1 with the same setup you show there same accumulator and a NH 656 baler I have been running that setup for 3 years now without any troubles. The accumulator requires 12 gpm. The specs say 18 but then you have to dampen it down on the flow control so it doesn't slam so 12 gpm works great for me. I have a front mounted hydraulic pump on my d17 with a tank I added to the side of the tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2017 at 8:32pm
A few years back, my neighbor bought a 12 row JD planter. Hooked it to his almost new JD tractor and it wouldn't run the vacuum pump. JD mechanic couldn't make it work so he had to use a different tractor to plant with.
 Next year he orders a new JD and specifies, he wants 3 hydraulic outlets and want it to run the planter.
 They called to tell him his new tractor was in and guess what, only 2 hydr outlets. After they added the 3rd, they still had to mess around a couple times to get it to work right
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd21man Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2017 at 6:28pm
dan73 its just a 1967 d17 series 4 has good strong hyds. i was talking to a AC dealer in athens ga and he said that he has fooled with this stuff alot and sometimes its can take a act of congress to get one to function right....
but i did end up getting 800 bales up with it with very little sweat lol since my AC is out lol
i think the gleaner wheels are what saved the day
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2017 at 7:18pm
Looks like you did a great job stacking those up. I have trouble lining up square enough to get them stacked too high.
I would think the serries 4 hydraulics would have plenty of flow for the accumulator.   I would probably check the pressure release to make sure your system is developing good pressure. The other thought that comes to mind is does the valve kick off when the accumulator comes to the end of stroke some valves will pop back to center. I don't know how the serries 4 hydraulics are actually setup as I have ever used one.
What I did on my tractor was setup a inline pair of disconnects that allow me to go from the pump to my out to my accumulator them back to my normal hydraulic valves.   I did this with a ball valve and two T's on either side with disconnects. The idea is if the accumulator is not hooked up the ball valve is open and oil flows through the ball valve to the input of the hydraulic spool valves. If I have the accumulator hooked to the two quick connects on either side of the ball valve I close the ball valve and fluid has to flow through the accumulator.   I also have a pressure release valve before the ball valve incase I forget to open the valve when I unhook the accumulator it won't dead head the pump. It is a little bit of work to set it up but I love the full flow without having to trig open a spool valve for the accumulator or also for a wood splitter or anything you might want to use with remote valves where you are not sitting in the tractor running it.
My guess is your pressure release is set too low and your not getting the pressure or your spool valve doesn't stay on and pops off when the accumulator come to the end of stroke.
Nice work getting the 800 bales our grass is only about 6 inches long now. We have a short season here only 100 days.
Oh I just thought. On my accumulator I added a second flow control to run the other cycle. That allows me to set the speed of both the flipper and the dump independent of each other. That made setting it up alot easier. The dealer told me oh you have to play with the flow on the tractor.   I didn't want to do that so I added a second flow control under the accumulator.   That might help as well.
Edited by Dan73 - 19 May 2017 at 7:21pm
