190 xt wont turn over |
showpig68
Topic: 190 xt wont turn overPosted: 14 May 2017 at 9:50pm |
have a 190 xt gas, running fine shutoff to add some hydralic fluid, went to start it and the starter just kinda thumps and fan blade turns about 1/4 turn and thats it. figure it is the battery but it started fine earlier. any other ideas? seems odd batter would go bad that quickly but i guess possible.
thanks!
Mrgoodwrench
Joined: 03 Apr 2011 Location: CHICORA PA Points: 2095 |
Posted: 15 May 2017 at 9:38pm |
Worst case...hydro locked. Coolant in a cylinder
There are 3 ways to do job GOOD, FAST, CHEAP. YOU MAY CHOOSE 2. If its FAST & CHEAP it won't be GOOD, if it's GOOD & CHEAP it won't be FAST, and if its GOOD & FAST it won't be CHEAP!!!!
DougS
Posted: 15 May 2017 at 9:50pm |
Clean and tighten the battery cables. If that doesn't do the trick check the battery.
shameless dude
Posted: 16 May 2017 at 12:32am |
sounds like starter replace/rebuild time. let it cool and see if it works better
Gary Burnett
Joined: 11 Sep 2009 Location: Virginia Points: 3134 |
Posted: 16 May 2017 at 1:51am |
I'd put on a set of jumper cables and see if that will start it.
