D14 oil to rocker arms |
coyote
Topic: D14 oil to rocker armsPosted: 14 May 2017 at 3:32pm |
How much oil should flow to rocker arms? Mine seems to pump very little to rocker arms. Cam bushing hole lines perfectly with hole in cam, good oil pressure on gage, runs good, but very little oil coming out external passage to oil rocker arms, govorner, and distributor.
Edited by coyote - 14 May 2017 at 3:57pm |
MACK
Posted: 14 May 2017 at 9:45pm |
If you have oil coming out of all eight rocker arms, that is good. If not check cork plugs in rocker shaft. MACK
coyote
Posted: 14 May 2017 at 9:51pm |
Thanks. Wasn't sure how much flow should come out of tube to rocker arm shaft. Mine doesn't flow near as much as brother-in-law's does but hold about same oil pressure. Guess as long as they're getting some, they're good.
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5201 |
Posted: 15 May 2017 at 5:06pm |
The elbow fitting in the head should have a very small hole in it to restrict the flow to the rockers. They don't need much. When that fitting gets replaced with a standard fitting it will flood the upper end and starve the crank.
HD6GTOM
Posted: 15 May 2017 at 8:33pm |
Ck that elbow Paulb is talking about, make sure there is not a chunk of dirt or metal caught in that small hole.
