8550 repair pictures (She lives!) |
Alex09(WI)
Joined: 15 Mar 2012 Location: CECIL WI Points: 1777 |
Topic: 8550 repair pictures (She lives!)Posted: 14 May 2017 at 12:15pm |
I have been helping repair an 8550 this past weeks. There were bad gears in the pto dropbox. I wasn't there for the teardown, but it was very time consuming.
Edited by Alex09(WI) - 16 May 2017 at 11:38pm |
www.awtractor.com
A&W TRACTOR 920-598-1287 KEEPING ALLIS-CHALMERS IN THE FIELDS THROUGH THE 21ST CENTURY |
shameless dude
Posted: 14 May 2017 at 1:25pm |
wow...that looks like a mell of a hess!
macvette
Joined: 13 Jun 2011 Location: nekoosa, wi Points: 1658 |
Posted: 14 May 2017 at 8:35pm |
Ya, what that Shameless Dude said = and I think he has seen it all! LOL!
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7639 |
Posted: 14 May 2017 at 8:42pm |
Man, I thought taking my 190 apart was a real job. That 8550 is huge! My new motto is: the bigger it is, the harder it is to fix!
victoryallis
Joined: 15 Apr 2010 Location: Ludington mi Points: 2887 |
Posted: 14 May 2017 at 9:55pm |
Looks like my 7580 last year that was miserable.
Mikez
Posted: 14 May 2017 at 10:36pm |
Yea any time a skid steer is in the job your doing something good
Alex09(WI)
Thanks(1)
Posted: 14 May 2017 at 11:36pm |
With a tractor this big, there is quite a bit of stuff to disconnect and remove just to get at the major parts. I am not sure how many man-hours will be in this repair, but im guessing a lot. We should have it going by the end of the week, we are waiting on an oil pump. The first start in 5 years should be quite a sight!
www.awtractor.com
Nathan (SD)
Joined: 11 Sep 2009 Location: Day County SD Points: 1304 |
Posted: 15 May 2017 at 11:56am |
I thought that dust on the windows looked fairly aged. Good to see another AC kept alive. |
Alex09(WI)
Posted: 16 May 2017 at 11:50pm |
We got her fired up today for the first time in 7 years! Torqing the mains and rods took 2 guys! 400 ft lbs on the mains! We'll get her in the fields later this week as we are already 2 weeks behind on our crops :(
www.awtractor.com
Alex09(WI)
Posted: 17 May 2017 at 8:01am |
[TUBE]84aPtUqzwQA[/TUBE]
www.awtractor.com
shameless dude
Posted: 17 May 2017 at 8:19am |
it sure sounds good! congrats!
JPG AUSTRALIA
Posted: 17 May 2017 at 9:28pm |
Well done,good on ya for keeping the old girl alive,great to see!,!
Tim NH
Joined: 16 Oct 2012 Location: Lancaster NH Points: 1155 |
Posted: 18 May 2017 at 5:57pm |
Wow, that's absolutely impressive. I can see you were some happy. That's the way to end a long project. Tim
JC-WI
Joined: 11 Sep 2009 Location: wisconsin Points: 34631 |
Posted: 18 May 2017 at 8:06pm |
liked how it started puffin smoke out of one ex. then out of the other ... and then both started smoken and finally she started hitting and caught hold and didn't take long to quit that smoke... and the low rumble with the turbo whine... Man that sounded good.
The truth is the truth, sugar coated or not. Trawler II says, "Remember that." |
Ryan Renko
Joined: 12 Sep 2009 Location: Edwardsville, I Points: 2349 |
Posted: 18 May 2017 at 8:48pm |
That old girl sounded great!!!! Congrats on your hard work!!! Lets see some action in the field!! Ryan
Unit3
Posted: 18 May 2017 at 9:50pm |
That looks like a long and very big project and I take my hat off to you, but, I want you to do one more thing before you close her up. I want you to pull the valve covers off and run it to check just how much oil is coming out of the rocker arms and down to the valves, adjusting screws, push rods, lifters, and cam. Oil pressure is not oil volume. Our old 4W305 ran @ 65 psi and would not even wet the top of the head after 10 minutes of running in the shop. Pulled the rocker arm shaft and ground a grove from the 4 O'clock hole up to around 3 and 9 to 2 and 10 O'clock. This let the oil out of the shaft and up through the rocker arms.
I know this sounds dumb and no one else on here will agree with me, and I don't care. I have seen it first hand how adjusting screws wear out and push rods turn blue from heat and bend. All caused from a lack of oil volume. When a WC makes more oil volume up top then 4W305, it is a bad day, but a far worse day is coming.
Edited by Unit3 - 18 May 2017 at 9:51pm |
Mikez
Posted: 18 May 2017 at 10:56pm |
That sounds awesome. You have a pit crew too
cbuttre835
Joined: 12 Nov 2010 Location: Peytonsville TN Points: 105 |
Posted: 20 May 2017 at 6:45pm |
What blew out of the front turbo?
C w/ 3rd gear out
D15 II factory 3 point WD (no motor!)(parts for sale!) WD 45 wide front |
Ted J
Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18967 |
Posted: 23 May 2017 at 10:08am |
WOW!! You've been busy since I last saw you! CONGRATS
Orange Blood
Joined: 29 Nov 2010 Location: ColoradoSprings Points: 4053 |
Posted: 23 May 2017 at 6:26pm |
We have had a couple like that, seems they take forever to get back to them sometimes.
Congrats on the first run!!!
Still in use:
HD7 WC C CA WD 2-WD45 WD45LP WD45D D14 3-D17 D17LP 2-D19D D19LP 190XTD 190XTLP 720 D21 220 7020 7030 7040 7045 3-7060 Projects: 3-U UC 2-G 2-B 2-C CA 7-WC RC WDLP WF D14 D21 210 7045 N7 |
GM Guy
Joined: 31 Jul 2012 Location: NW KS / S.C. ID Points: 1988 |
Posted: 24 May 2017 at 11:25pm |
Props for keeping it alive and out of the bonepile!
She sounds pretty nasty! The 516 and the 731 and 844 have a startup that will give you goosebumps, that is for sure. :) |
Gleaner: the properly engineered and built combine.
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help. |
Mikez
Posted: 24 May 2017 at 11:31pm |
Wish we had guys like you around here to work on stuff
Alex09(WI)
Posted: 25 May 2017 at 12:22am |
It was a day to remember around there. The tractor had been sitting in the same spot in the shed for the past 7 years. The owner David was very happy to get it going (he was cranking in the cab) That day was also the 5 year aniv. of his father's death. He is an all allis farm with his daughter and will be getting it in the field this weekend hopefully!
The shirtless guy on the engine was checking for oil on the rockers which did show up within 60 seconds :) We are currently repairing the top pivot articulating ball which has a lot of vertical slop. It has been raining here so we have not been able to plant or work much ground lately, but we will be chisel plowing with it soon. I will get some pictures for sure!
Yes, those turbo(s) sure do sound good! First grey smoke, then black, then it fired up! |
www.awtractor.com
Tracy Martin TN
Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10937 |
Posted: 25 May 2017 at 8:44am |
Looks and sounds great!
AC7060IL
Joined: 19 Aug 2012 Location: central IL Points: 3671 |
Posted: 25 May 2017 at 10:16am |
Awesome! Thanks for posting pics & video.
Great startup video! Sorry to hear of your friend'a loss of loved one. Congrats to their restored AC8550 & their all ALLIS farm. |
