7010 PD Hi-Lo Cable Adjustment?
Roscoe62 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roscoe62 Quote  Post ReplyReply Direct Link To This Post Topic: 7010 PD Hi-Lo Cable Adjustment?
    Posted: 13 May 2017 at 10:25am
I was having problems getting the trans into low, only after multiple shifts between hi and lo.
So I put on a new SMALL shifter cable today, and it still won't go into low.  The lever goes into position, but the trans does not.  After I put the new cable on, the lever would not go into the high position until I lengthened the LARGE shifter cable by one turn.
Is there a procedure somewhere for this?
thanks,
Roscoe
Edited by Roscoe62 - 13 May 2017 at 11:01am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roscoe62 Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2017 at 1:05pm
It sometimes will go in low, sometimes won't.  I am clueless what to do next, if anyone has done this before?
Thanks,
Roscoe.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2017 at 1:46pm
Sounds like something is moving maybe where the cable is attached to?Just a guess, I have no experience with these but want to learn , please post what the fix was when you get it
grinder220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2017 at 2:23pm
My 7040 ps is the same way,put new cables on and didn't help. I noticed the park lock doesn't come out completely on its own,cable sticks a little so maybe that has something to do with it. Thats the only cable I didn't replace yet.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2017 at 9:59pm
Take the side cover off the console, down at floor there is a hole in linkage where you can hook a spring. AGCO 70514773 bailer spring is just right to move linkage for better shifting.    MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roscoe62 Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2017 at 6:12am
Thanks MACK, I was hoping you would see this and reply.
I put it all back together since I had to start mowing yesterday.  I will take the cover back off after church and if I can't figure out what you  mean, I will post back.
One good thing since I had it all apart, I did weld the brace to the PTO cable bracket, as Doc said, to stiffen it up and allow me to take it out of gear.  That worked like a charm.  I also took the slop out of the transmission foot clutch cable by replacing the worn, sloppy ball end with a good one.  Now my trans brake works again.
It sure is rough not having Lo range though.  1 Hi-Hi is too slow and 2 Hi-Lo is too fast for mowing rough ground.  Can't wait to get my Lo range back again.
Thanks again.
Roscoe.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roscoe62 Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2017 at 7:07am
Couldn't wait, so I did it this morning.  Unbelievable.  Works first time, every time.
I just used a heavy spring in the spare parts bin.   Photos below:
Thanks, thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roscoe62 Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2017 at 7:12am
Close up:
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2017 at 7:16am
Perfect!
