190XT - Fuel issue
Sundre roper View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sundre roper Quote  Post ReplyReply Direct Link To This Post Topic: 190XT - Fuel issue
    Posted: 13 May 2017 at 9:45am
good day all, I had the occasion to run outta fuel this spring (yup stupid me) Regardless I am having a hard time getting the old girl back running consistently. I have changed fuel filters, cleaned (both) sediment bowls, bled out all the injectors etc. to this point. What occurs is I can run her for anywhere from an hour to four hours and all of a sudden the motor loses power and will stall. I wait a matter of minutes and restart with no problem. My question is: what else should I look for, clean, or perhaps need to replace?
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2017 at 9:47pm
Could be lots of crud in the tank that blocks the outlets on occasion.  Mine had a lot.  Don't just look at the sediment bowls.  If everything is good there, I would start looking at the injector pump.  Might be giving up the ghost little by little.
This page was generated in 0.555 seconds.
