7030 not getting fuel
chaoticfields001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaoticfields001 Quote  Post ReplyReply Direct Link To This Post Topic: 7030 not getting fuel
    Posted: 10 May 2017 at 5:17pm
  I recently purchased a 7030 that has been sitting in a shed for several years.
Got it home drained the fuel put new fuel in changed fuel filter cracked loose the fuel line to the injection pump and used primer pump to get fuel to that point. Then cracked loose fittings on injectors 2-6 couldn't get #1 loose so loosened it at pump cranked engine but no fuel seems to be getting through pump any ideas or suggestions
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2017 at 6:17pm
Setting is a bad word on diesel fuel these days, take a flashlight and peek in the tank, if I have trouble with one like you describe I start st the tank, clean it if it needs it, then on up to the pump, the Roosa a,s can take alot but gotta have good fuel, I think those had a lift pump, is it working?
Edited by DougG - 10 May 2017 at 6:24pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2017 at 9:23pm
Metering valve stuck or plungers are stuck. Remove top cover, there is a valve under cross shaft. Work it back and forth to free it up only if there is fuel around it. If that don't it, might as well send it to pump shop.      MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2017 at 9:57pm
....and set the timing marks together BEFORE removing it!!
