Install water pump on AC 7040
jazzsuds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jazzsuds Quote  Post ReplyReply Direct Link To This Post Topic: Install water pump on AC 7040
    Posted: 08 May 2017 at 9:05pm
Allis Chalmers 7040.Changing a water pump. I used a pulley and pulled the pulley off of shaft.All bolts are removed but I can't get the pump to come off? Any help will be appreciated
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2017 at 10:08pm
There is a ällen head bolt, did you find it? Another down low that is kinda hard to seen.    MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote jazzsuds Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2017 at 12:50am
Thanks Mack. Yes I did find that when I pulled the pulley off but it still will not come off? Any other ideas?
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote jazzsuds Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2017 at 8:38am
Here is a picture of what is left on the water pump I'm trying to remove. Is it that round piece at the end of the shaft before the pump That is keeping the pump from coming off? If so how do I get it off? Thanks
Edited by jazzsuds - 10 May 2017 at 8:40am
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2017 at 10:51am
Probably just glue holding it in place. Try a dead blow hammer.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote jazzsuds Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2017 at 11:02am
OK thanks I will try it
This page was generated in 3.915 seconds.
