All-crop "quiz" page2 |
Mikez
Topic: All-crop "quiz" page2Posted: 08 May 2017 at 8:43pm |
Ok guys here's page 2
7. The AC cleaning method features air control by: ( ) a. Adjustment of sawtooth wind valves. ( ) b. Adjustable blinds and shields. ( ) c. A simple, non-adjustable system of air pipes. 8. Proper header balance and weight distribution are assured in the "66" by: ( ) a. Hydraulic lift. ( ) b. Center suspension balance spring. ( ) c. 2 balance springs - one on each side of header. 9. The lower draper feeds crop to cylinder by taking it: ( ) a. Straight back from sickle in a wide, smooth stream. ( ) b. Sideways from the sickle to another conveyer. ( ) c. Away from sickle in bunches to keep cylinder loaded. 10. Upper draper is a big aid to feeding because it travels: ( ) a. Slower than lower draper to bunch up crop for better shelling. ( ) b. Faster than lower draper to comb and thin out crops. ( ) c. The same speed as lower draper to prevent under feeding. 11. Both spike-tooth and rasp bar cylinders are harsh on crops because of: ( ) a. Steel-on-steel threshing action. ( ) b. Their high speed. ( ) c. Their diameter. 12. The combination wood-steel " step-up" rack in the "66" ( ) a. Has 5 steps to provide uniform travel. ( ) b. Provides a slow, easy ride for the straw. ( ) c. Has 3 steps and 3 removable fish backs. 13. The steel section of the rack behind the cylinder: ( ) a. Moves straw away evenly and helps prevent bunching and back lashing. ( ) b. Holds straw back for better separation. ( ) c. Has openings in the tops of the cross pieces for grain to fall through. Enjoy guys |
Mikez
Posted: 11 May 2017 at 7:30pm |
You guys don't want to play anymore
Mikez
Posted: 15 May 2017 at 10:37am |
Last day before I list the next page latter tonight
CrestonM
Joined: 08 Sep 2014 Location: Oklahoma Points: 8479 |
Posted: 15 May 2017 at 11:56am |
Been away from the computer for a few days. I do enjoy these. Thanks
7. A 8. B (not 100% sure) 9. A 10. B 11. A 12. C 13. A (not 100% sure) |
Mikez
Posted: 15 May 2017 at 9:29pm |
Ok here we go.
7. A. Adjustment of sawtooth wind valves. 8. B. Center suspension balance spring. 9. A. Straight back from sickle in a wide, smooth stream. 10. B. faster than lower draper to comb and thin out crops. 11. A. Steel-on-steel threshing action. 12. C. Has 3 steps and 3 removable fish backs. 13. A. Moves straw away evenly and helps prevent bunching and back lashing. |
