Seed plate info
Shamrock Farms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Shamrock Farms Quote  Post ReplyReply Direct Link To This Post Topic: Seed plate info
    Posted: 08 May 2017 at 8:39pm
Greetings all. I'm new to the forum and AC equipment. I recently acquired a model 74 planter and am looking for information on seed plates. It came with corn,bean and sorghum plates. I'm wanting to plant a sunflower patch to dove hunt over and am wondering if there is a sunflower plate and/or spacer required since the black oil sunflower seeds are so thin. Any info or help including advice,part numbers and contacts for purchasing these parts is much appreciated. THANKS!
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2017 at 9:40pm
are those plates the big ones that mount vertical? I have some plates, but will hafta look at them to see what seed they may take.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Shamrock Farms Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2017 at 9:44pm
No these mount horizontally and are about 7 inches in dia. The ones that came with it are aluminum but I am not opposed to using plastic ones.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2017 at 10:12pm
I gots skads of those, lemme check
Post Options Post Options   Thanks (0) Thanks(0)   Quote Shamrock Farms Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2017 at 10:25pm
Great! I only need 2 since this is a 2 row planter now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2017 at 10:26pm
I looked on "Lincoln ag" web pages, and the sunflower plates are a lot like the corn plates for flat kernals. do you have the adapters to make the deere style plates work in allis planters?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Shamrock Farms Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2017 at 10:29pm
No, sure don't. It only came with the cast aluminum AC plates.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2017 at 3:29am
if you use the deere plastic plates, you hafta have an adapter that goes in the middle. I think I also have some SS plates, and some cast iron ones, i'll look to see what they are for.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2017 at 6:20am
Big difference in sunflower seeds.Grey stripped are very large the oil type are about
half that size.Also been my experience if there are many deer around they clip off the Sunflowers not long after they come up same with Blackeye peas.Broadcasting
Buckwheat and Sunn Hemp as a Summer draw will work a lot better
Post Options Post Options   Thanks (0) Thanks(0)   Quote Shamrock Farms Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2017 at 7:07am
I'm planning on planting the smaller black oil sunflowers for a dove plot. You are correct that the deer love those new sprouts and I plan on losing a few but hope they won't clean out a couple acres. In past years I've just broadcast the seeds but they were just too inconsistent and mostly overcrowded resulting in smaller heads. The ones that the deer hit still produced heads (actually multiple heads) but were noticeably smaller.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2017 at 7:26am
When I broadcast seed on seed plots I mix the seed in the fertilizer and can control the
amount and thickness of the seed better.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2017 at 6:24pm
You can take some bondo, fill the holes in a set of plates, then grind out the holes, to fit your seed.  Just use a dremel tool, and grind till the hole fits your average SF seed...Wink
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2017 at 8:39pm
I think you can get new plastic ones pretty cheap,  Might be the easiest answer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Shamrock Farms Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2017 at 5:14pm
Update: I found a dealer with an old set of plates and a set of spacers that will work. I think they may be the popcorn/sunflower plates that are listed on some charts but can't read the numbers.Also picked up a set of adapters to use the Deere style plates. Just took a few phone calls and a road trip to the dealer. Thanks everybody for the input.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2017 at 8:54pm
new plastic plates are $25. each now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Shamrock Farms Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2017 at 6:36am
I got a heck of a deal then...plates and adapters for $15 but had to drive 115 miles to pick em up.
This page was generated in 0.820 seconds.
