Locked steering joint on Hay Wagon
MIguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MIguy Quote  Post ReplyReply Direct Link To This Post Topic: Locked steering joint on Hay Wagon
    Posted: 08 May 2017 at 7:07pm
One steering assembly locked up over the winter on my Allis-Chalmers  Hay Wagon cat. number 2013954.
Cannot find a parts or repair manual on line for wagon.
Removed bolt and washer on top of shaft, cannot get the shaft loose to drop drown out of holder in frame. Need a parts manual shot to pull and clean the shaft from frame down to axle and wheel assembly.
If no parts manual PDF available, a "How To" suggestion would be much appreciated.
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2017 at 7:29pm
Torch outside and hammer down. Wire brush and/ or sandpaper shaft and re-install. No manual needed. Lubricate prior to reassembly and put in grease zerk if none (optional).
Post Options Post Options   Thanks (0) Thanks(0)   Quote MIguy Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2017 at 7:56pm
Thank you Stan
Have been trying heat and then using a maul to move spindle side to side without success. Will smack it down tomorrow!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2017 at 8:00pm
Had one of ours freeze up last year and was able to get it done the way I mentioned. Best of luck.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2017 at 8:09pm
Kroil,patience, and knowing not to swell the end of upright shaft. Don't over do it! HTH Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2017 at 10:11pm
I had a Kory gear do the same thing, I couldn't pound that SUCKER out, sprayed it everyday for months. finally took it to a body shop and they power pressed it out, we cleaned, and used that metal cloth to clean up the shaft, greased it, and it went back together and stayed loose ever since. be careful not to polish off to much, or it'll wave some while pulling.
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2017 at 12:40am
I used a thin cutting wheel on a 4 inch grinder and split the outside tube right by the weld. I reassembled and re-welded it.
This was after I heated for almost an hour to get it red hot. I pounded for another half hour and it moved about 1/8 inch.
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2017 at 6:23am
Been there and done that also, heat will be your best friend.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2017 at 6:35am
Been there, done that. Exhausting, but it works. Heat, pound, twist back and forth. Nearly wore myself to a nub, but I got it. Do you have a rosebud end for your torch? Get it hot, douse with atf and stuff, keep working. It ain't fun.
KenBWisc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KenBWisc Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2017 at 8:28am
This is what God made a grease gun for!
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2017 at 11:26am
Doggone I just sold a parts/owners manual for that wagon last weekend. Good luck with her.
This page was generated in 0.267 seconds.
