New off color tractor
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Topic: New off color tractor
    Posted: 05 May 2017 at 9:43pm
Put on 900 miles today to get my new tractor. It's a Ford Model T with a tractor conversion kit on it. I'll stick my spare engine in it and it should be ready to go. You basically remove the rear wheels and install the tag axle and braces and boom, poor mans tractor. This one has been shortened about 3 feet.
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2017 at 9:48pm
I like that!
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2017 at 10:23pm
Awesome!! Ford "tractor" bug strikes again! Lol
Edited by CrestonM - 05 May 2017 at 10:23pm
chuck (WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chuck (WI) Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2017 at 10:29pm
Never knew they did such a thing, maybe that's what brought em to the TW series.
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2017 at 12:18am
Wow! Are times getting that tough!
I thought Trump was making things better? (joking)
It looks great!
Does/did it run on alcohol or gasoline?
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2017 at 12:41am
I've seen pics and read stories on them things! but was never really able to find out how much they could pull, like plows and disks? maybe they just used them to seeding and harrowing? had to be light duty stuff since it is a ford! (poke,poke)
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2017 at 12:55am
Ouch Ouch! Lol
JayIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayIN Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2017 at 4:29am
Seen them before at shows. Very, very cool. Would love th have one!
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2017 at 5:14am
Cool Man!!!
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2017 at 6:03am
Bugs in general are real popular at the rolog show and I see then at other shows also.  I bet they worked real good for haying thinking more the ones with rubber tires and twin transmissions.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2017 at 6:05am
Link to a picture of a conversion:
Gary
http://www.mtfca.com/discus/messages/257047/278922.html?1340397506
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2017 at 6:47am
I'm not sure what they were capable of but about all there was is horse drawn equipment at the time so I guess anything a horse can do? It should go good with the Doodlebug that I built. My bug has a Model A tranny behind the T tranny so there are lots of gears to choose from.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2017 at 7:54am
So Lonnie.....how fast will that one with 2 trannys go??? Lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2017 at 9:45am
isn't that what that golfer used all the time?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2017 at 10:43am
The 2 trannys won't get you going any faster but you have a pile of granny gears to pick from.
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2017 at 10:43am
Have seen a few around Ohio at shows
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2017 at 12:13pm
I have a book on model Ts. There were several variations on converting Ts to tractors. Some fairly simple, some harder like changing the axle. There was also a factor option for the TT trucks (that had a worm drive rear axle with a higher ratio so more torque to the wheels than the car axle but using the same engine and transmission up front) to add a three speed lever shift transmission right behind the standard T transmission. I have found a least half a dozen different transmissions used. The top speed of the truck was about 25 mph with the worm drive rear axle. The three speed plus reverse option gave the truck lots of slow speeds and one confusing forward gear with both transmissions in reverse.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2017 at 4:19pm
My TT truck has the high speed (5.16:1) rearend it and my Doodlebug has the low speed (7.25:1) in it. Like you said the high speed tops out at around 25 mph and the low speed about 18 mph. My TT had a Jumbo 3 speed Transmission behind the stock one which would give you underdrive, straight through and overdrive so it would go few miles an hour faster but I removed it since I don't haul anything I didn't need the underdrive and those trannys are very noisy with straight cut gears.
This page was generated in 0.049 seconds.
