8070 8.3 is done. I hope!
randy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Topic: 8070 8.3 is done. I hope!
    Posted: 05 May 2017 at 5:26pm
Finished the 8.3 conversion! Thanks to Ed and all the others that gave me advice and help!
Nice running and pulling tractor.
Randy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2017 at 6:04pm
Awesome have any more pictures
WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2017 at 6:40pm
That will be some tractor with 8.3.
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2017 at 9:54pm
If I did it right 350ci/5.7L=61.4ci*8.3L=509ci That should do right nice. I also see the starter on the same side as the batteries. I like that. Great job.
TREVMAN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TREVMAN Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2017 at 10:07pm
8.3L = 505 cid  Litre = 61.1 cubes. Easy 175 pto out of 8.3. Trev.
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2017 at 10:43pm
Beautiful!  Any idea how many hours in the job?
Allis Express participant
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2017 at 2:03am
looks good! hope it works o-k for you, it should!
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2017 at 6:55am
Hours, too many to count! If I had started with a good engine, had a adapter plate, flywheel and all the other odds and ends, so it was putting it in it wouldnt be too bad. I did a total rebuild of the engine, bought the flywheel and adapter plate, and adapted or made a lot of brackets, motor mounts, alternator and other things. Lots of trial and error. The second one would be much quicker.
It fit like it was made for it. I will get more pictures today.
Ed at heritage diesel did the pump work and his buddy Rob were a big help!
Got about 60 hours on it so far, so good!
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2017 at 12:20pm
More pics.
Sagefarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sagefarmer Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2017 at 3:51pm
Nice job, Gets me inspired. I know where one is sitting that has a cummins in it already. Farmer ran it hot, drove it home and parked it. I just have not been brave enough to ask what he will take for it. I don't need another project right now ,lol. Post all the pic you have.
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2017 at 9:50pm
looks great, just looks like that cummins ought to been there in the first place,, not knockin the 426...I think the higher HP tractors sure needed a updated engine...
I jus think the 8000 series were a really good machine,,,,way ahead of their time and economy of the early 80's
Post Options Post Options   Thanks (0) Thanks(0)   Quote TREVMAN Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2017 at 11:43am
You did a very good job, you should be proud. It always amazes me what people can do. Trev.
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2017 at 1:34pm
Is there a muffler?
Or did you go a size bigger on the stack above the hood?
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2017 at 6:58am
No muffler, its a standard Allis exhaust pipe with a chrome pipe over it. Got both pipes from Thorume, in East Prairie Mo. I havent got an asperator on it yet, maybe later.
orangeman69 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman69 Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2017 at 3:59pm
Would recommend some sort of heat shield next to the turbo, We've had it burn the paint off the side panel!
d17,d17nfpuller,d-17IVdiesel,d19gas,d19diesel nf,d21seriesII,180,190xtseries III,200,210,7020,7060,7080w/8.3cummins,8070fwa w/8.3cummins,8550 185 w/322 original hrs.
