82S side mower bracket?
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomstractorsandtoys Quote  Post ReplyReply Direct Link To This Post Topic: 82S side mower bracket?
    Posted: 03 May 2017 at 9:34pm
I just bought a 82S side mower off Craigslist. I mailed a check for it as I can't get it for a week. It came off a D14 and I want to put it on a series II D15. Will I need any different parts? I think that the two tractors are close enough to the same that it should work. The owner says he has used it and has all the mounting brackets. I am looking forward to using it to trim field edges and along our stream banks. Tom
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2017 at 10:09pm
Is your 15 snap coupler or 3pt
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomstractorsandtoys Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2017 at 6:50am
My 15 is snap coupler. Tom
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2017 at 7:05am
I can't see any reason it wouldn't fit,be sure you get the spacer that bolts to the belt
pulley hole cover lots of times those are left on the tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomstractorsandtoys Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2017 at 7:18am
My 15 has one of those on it from the last owner.  Thanks for the reply.
