PISTON SLEEVES
augercreek View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote augercreek Quote  Post ReplyReply Direct Link To This Post Topic: PISTON SLEEVES
    Posted: 03 May 2017 at 1:19pm
Does the 170 with 226 engine have dry or wet sleeves? I pressurized the block and we are getting water in the oil pan.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2017 at 1:26pm
wet sleeves.  you have bad o-rings, or a cracked block
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2017 at 10:37pm
With the pan off,pressure it up and you can see where where it comes from.Likey a sleeve o-ring.Better than guessing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote augercreek Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2017 at 4:43am
Thanks much guys.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2017 at 7:25am
Never seen a bad sleeve Oring on a D-17 gasser. Cracked block, head gasket or frost plug in the top of the cylinder head are the most common issues.
