WD 45 shifter help needed
Dads 45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dads 45 Quote  Post ReplyReply Direct Link To This Post Topic: WD 45 shifter help needed
    Posted: 02 May 2017 at 9:15pm
My new to me tractor has a problem. Shifter popped out of position when shifting 2nd to 4th. Took out the snap ring and thin ring below it. Shifter looks great end-wise and no wear in slots or square ended alignment pivot pins. My question is the thin ring. It came out with the flat side down away from the snap ring. I suspect it should be flipped over with flat side against snap ring. Or is it in correctly?
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2017 at 12:30am
Flipping it over will allow more up-down play in the shift tower. Sounds like you have plenty already.
dt1050 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dt1050 Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2017 at 4:29am
my wd 45 had a couple of shims, they looked like bent washers, to keep it tight.  but if you shifted into 4th quick the shifter would still pop out.  I just stopped using 4th...lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2017 at 6:34am
Put it together right and shim if necessary. If the bottom "ball end" of the shifter is wore it can add to this problem. JMO If it's like the ring on the B, it has a radius built in to match the shift lever pivot .
This page was generated in 0.554 seconds.
