monoframe hydro reset parts
IHCfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IHCfarmer Quote  Post ReplyReply Direct Link To This Post Topic: monoframe hydro reset parts
    Posted: 02 May 2017 at 9:00am
Can a person still get parts someplace to keep a 3000 series monoframe with hydraulic reset bottoms working
I found a pair of 3000 series monoframe's and would like to fix and use them for plowing as I plow probably around 300 acres a year! So getting parts is very important!! Anyone have a source for parts for the accumulator plowshares whatever a guy might need!
And yes the plow will be pulled with a red tractor.
And yes there's a story on why I want a allis chalmers plow!!
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2017 at 9:46am
Well, I can't help on location of reset parts, but I would like to hear the story on an AC plow!
Post Options Post Options   Thanks (0) Thanks(0)   Quote IHCfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2017 at 10:26am
Ok here's the story in a nutshell I met and married my wife she's an Allis Chalmers Gal she inherited her families to two-twenty allis tractor! (So yes we have one Orange tractor on the farm ) well I thought it would be nice to have an orange plow to go with it so at an auction a couple years ago I got an old 2000 monoframe plow Shear pin trip For 500$ so I thought why not. Then I made the mistake of using it and mind you I have three other plows!(2 IH and 1 white)and they're all nice plows BUT that CHEAP ALLIS CHALMERS PLOW IS THE BEST PLOWING PLOW I HAVE!! So that's basically the story and now I would like a bigger allis plow and use it as my primary plow and I know that parts can be a problem so here we are!
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2017 at 10:37am
OK now we need pics of plow, 220, especially the 220 and even those reds you gots
A few years ago you could still get most parts, even the plates on each side of the plow bottom beam. I checked because my trip mono frame was used while the trips were froze up and a couple plates were cracked. Now I have a 6 bottom 2000 with hydraulic reset but will need yo go through it before using it.
Edited by Lonn - 02 May 2017 at 10:39am
Wink
I am a Russian Bot
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2017 at 11:00am
I think Butch(OH) had some kits made up with all the seals and things to rebuild the cylinders. He probably knows quite a bit about them after all the work he did to his.
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2017 at 11:08am
Just remember pulling that Allis plow with the Two Twenty has spoiled you, the equivalent required Red one is a Magnum 340 at a minimum!!!  LOLLOLLOL
I grew up Allis, currently live Allis, and have you guessed it, Orange Blood, but I spent many hours on Red ones helping the neighbor out many a summer growing up, and I won't tell anyone around here, but I like the Red ones also.  Wink
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote IHCfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2017 at 7:09am
The biggest thing I'm worried about is getting parts for the hydraulic reset I have heard you can't get a new accumulator if you need one and I have heard you can't get plow points for I think it's called the 392 bottom(my plow has the 387 bottom and fleet farm stocks them for it) I haven't bought the plows yet! And I don't want them if I can't use them! What they are is one 3000 monoframe plow 7-16 in the furrow and the other is a 3000 monoframe 6-16's on the land!! Both very cool heavy build looking plows. They both need some work as I don't think they have been used in 20 years and been sitting in a tree line!
One more question what anyone think they are worth??????
Thanks
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2017 at 8:27am
Yes the 387 is the one you want for easy to find wear parts but the 387 shares also work on 392 bottoms if you also switch to 387 type off set land sides. The difference between the 392 and 387 share being the nose of the 387 share is moved left  to work with the off-set land sides of that series bottom.  It all bolts up and works as long as you switch everything over.
Yes I had some kits made up for the reset cylinders but found out later you can buy them from Baum Hydraulics for same price so I didn't have any more made after the first batch sold out.
Edited by Butch(OH) - 03 May 2017 at 8:27am
Post Options Post Options   Thanks (0) Thanks(0)   Quote IHCfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2017 at 9:03am
Ok now what if the accumulator is bad ?? Or are they pretty tough and good and reliable
Post Options Post Options   Thanks (0) Thanks(0)   Quote IHCfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2017 at 9:28am
And how much for the kit the agco dealer told me 87$ that sound like a lot for O rings and gaskets
allisguy.11 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisguy.11 Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2017 at 10:04am
following on accumulator... ive got one I'm getting going too
aras View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote aras Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2017 at 10:22am
I think I looked at the plows your are talking about.
Kevin in WA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin in WA Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2017 at 10:28am
The accumulators rarely give trouble, if you would need one a hydraulic shop should be able to match one up, they are nothing out of the ordinary.
This page was generated in 0.067 seconds.
