Bar balance spring - 80T Trail Mower
Farmer Tom View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Farmer Tom Quote  Post ReplyReply Direct Link To This Post Topic: Bar balance spring - 80T Trail Mower
    Posted: 01 May 2017 at 11:56am
I am in the process of reconditioning my 80T Trail Mower (Serial #T33xx), but getting ahold of a new "bar balance spring - A/C part #70804141) is not possible since it is no longer available from AGCO, so it looks like I will have to substitute another spring for it.
Does anyone have any specifics (O.A. length, O.A. diameter, spring metal diameter, tension factors, etc.) or a source for a replacement spring that I could use in its place? The current spring has been welded on and I am not sure it's even the correct one to boot.
Any help/information would be appreciated.
Thanks in advance; Farmer Tom
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2017 at 6:53pm
I have one of those mowers for parts is this the spring that pararells the lift cylinder?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Farmer Tom Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2017 at 11:31pm
Gary;
No it is not that one; according to the parts/set up manual that spring is referred to as the "inner shoe balance spring". The spring I am looking for is at the rear of the mower and goes between the pto drive tailpiece and the twin-wheel drive unit. Thanks, Tom
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2017 at 12:50am
Tom...Your # is correct.  I sent you a email with pics and measurements.  Came off an 80T. There's more than one of those springs and some times they get interchanged.  So give the info a look....Thanks...Dale
Orangereborn
Dale Schafer
964?? 192nd Ave
New Richmond, WI 54017
715-247-3079
715-781-2055
Orangereborn@hotmail.com
