D15 II Transmision oil?
copyrite1972 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote copyrite1972 Quote  Post ReplyReply Direct Link To This Post Topic: D15 II Transmision oil?
    Posted: 29 Apr 2017 at 8:25pm
I am just about to wrap up the repair/rebuild of my rear lift arm ram. I pulled the plug under the rear differential to drain the rear end, is there another drain for the front? Also, what do I refill the transmission with? And how much does it take? The lift ram has been leaking into the transmission for a long time, so the transmission has basically been working with 303 in it forever.
I'll get a thread up about it when I get done, I've even got pictures!
Thanks in advance!
D15 Series II
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2017 at 8:11am
If I remember  right, there is a drain plug on bottom of transmission as well as under diff.
 I would Ago 821 or a good universal hydraulic wet brake oil.     MACK
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2017 at 12:28pm
Universal hydraulic and transmission oil
Thanks & God Bless
Dennis
wbecker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wbecker Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2017 at 2:30pm
My manual says "Hydraulic pump 9-7/8 Qt."
"Transmission 14 3/4 QT."
Post Options Post Options   Thanks (0) Thanks(0)   Quote copyrite1972 Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2017 at 6:37pm
Thanks Fellers! Guess I'm of for more oil!
D15 Series II
This page was generated in 0.127 seconds.
