7080
ACofGraton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACofGraton Quote  Post ReplyReply Direct Link To This Post Topic: 7080
    Posted: 28 Apr 2017 at 10:32pm
I was wondering what the front grille AC symbol should look like on a 1980 AC 7080? Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2017 at 11:22pm
I don't think mine had one
Dgrader View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dgrader Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2017 at 3:39am
7000's didn't have it. Only 8000 series.
Ya cain't fix stupid.
Joe(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2017 at 6:22am
Here is a pic from an original add. You can clearly see the emblem. They are a steel box with an Allis decal.
7080
Life is simpler when you plow around the stump.
45 turboa- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 45 turboa- Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2017 at 8:01am
I still have some of the emblems that we made up for the black bellys and the 8000 series they are made out of aluminum instead of plastic .
turbocharged
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2017 at 9:11am
The steel box measures 3-3/8" X 3-3/8" X1-1/4". The 7000 series came with them but I think a lot have fell off. They were hard to secure, welded to mesh.
John D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John D Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2017 at 9:22am
Here is a shot of our 7060
1964 D17 series 3
djg390 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djg390 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2017 at 9:28am
Here's a pic of the grill from one of our 7080's...not sure what's it's made out of.  Both of our 7080's have them and they are both brown belly's.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2017 at 9:34am
I guess i'll go look again....
LB0442 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LB0442 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2017 at 11:54am
Here is one on my 7080. It is plastic, held on with screws on the backside.
Toscani NE SD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Toscani NE SD Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2017 at 9:34pm
I believe brown bellies had the metal box style that had little tabs bent over to hold on and black bellies had the nicer aluminum emblem with two screws holding them on, I have both styles in my collection.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Toscani NE SD Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2017 at 9:40pm
I need to correct myself, I just looked and the later one is plastic with 3 screws holding them on, I was mistaken on aluminum, those where for
later b series garden tractors.
Daehler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daehler Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2017 at 11:13pm
The 7045 on the farm never came with an emblem, its a 1980 model. The 1980 7080 has the newer plastic emblem like 8000 series. I think 1980 is when the switched style of emblems.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2017 at 10:21am
My 1979 7080 has the box style on it, as do my 76, 7060 and 7040. Maybe 79/80 was the cut off for the new emblem.
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2017 at 10:37am
 Here is my 1980 7045.
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2017 at 1:48pm
All 7000 series had an emblem on the upper grille screen. Either the square metal box style or the later style. Many fell off or got taken off, but when it left the Factory in Milwaukee it had something.
