Loose fan
jazzsuds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jazzsuds Quote  Post ReplyReply Direct Link To This Post Topic: Loose fan
    Posted: 27 Apr 2017 at 3:21pm
I have an Allis Chalmers 7040 and the fan is slightly loose. Do I just tighten up the bolts holding it on or is there a bushing that needs to be replaced?
mattb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mattb Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2017 at 3:22pm
better check your water pump bearing
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2017 at 4:45pm
Replace water pump before fan goes through radiator.     MACK
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2017 at 6:58am
Like Mack says......I suppose there is a very slim chance it could just be bolts, but unlikely.
ocharry View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ocharry Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2017 at 12:46pm
i was gona say the same thing Mack did
you could check the bolts but if that shaft come outa that pump housing its gona be UGLY
ocharry
Post Options Post Options   Thanks (0) Thanks(0)   Quote jazzsuds Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2017 at 2:51pm
Thanks Gents. I bought a new pump. Anything I should be aware of when I do the replacement?
farmboy520 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmboy520 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2017 at 2:54pm
You might want to change the thermostats while it is drained down so you know there won't be an issue later
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2017 at 3:45pm
Good luck getting the aluminum fan spacer off the nose of the water pump hub.
This page was generated in 0.065 seconds.
