WC Wide Front End
ZachD89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ZachD89 Quote  Post ReplyReply Direct Link To This Post Topic: WC Wide Front End
    Posted: 25 Apr 2017 at 11:28am
I recently bought a WC wide front end and was thinking about putting it on my 35 unstyled WC. My question is did all of the Wc's come with the wide front option or just the styled? And will my 17 Inch front rims work on the wide front? I do not have a picture of the wide front but I posted a picture of the wc I am wanting to put it on. Thanks
Edited by ZachD89 - 25 Apr 2017 at 11:29am
37 A,37 Waukesha B,35 WC,38 WF,M crawler,49 WF,49 WD,53 WD45,39 and 40 RC,47 WC,41 B,39 B,48G,48,C,59D10,D21,IB,B10,B12,B208,B1,Roto Bale Loader, sp100 combine, allcrop 66, L3 Gleaner
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2017 at 1:05pm
The 17's will not work ,unless u can get a bearing that will work in the 17 inch hub to go to the spindle on wide front .
Edited by Fred in Pa - 25 Apr 2017 at 1:06pm
nonetheless ,still dead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ZachD89 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2017 at 7:13pm
Ok so the spindles are different. Thanks
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2017 at 9:45pm
Not that it matters. I am not with the correct police, but what was the first and last year for the arched axle?
CALEBnOK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CALEBnOK Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2017 at 3:49pm
Front wheels from a u or UC will work if your looking for round spokes
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2017 at 4:51pm
Not sure on the years for the cast iron arched front end, but in 1947 they came out with the 3 bolt wide front for the WD and WC these early wide fronts are easy to spot because they have a weld along the top side of the front end, almost like they welded 2 channels together to form the front end, the later 3 bolt front ends have a 1 piece formed channel for the front end.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ZachD89 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2017 at 7:04pm
I didn't get to work on the wide front yet but hopefully I will this weekend. But I hope my 17 inch wheels will fit if I get different bearings but I don't know much about the WC wide fronts.
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2017 at 9:48am
All of the "flat top" WCs  we sold were the tricycle type.  In fact, I was unaware of a wide front end for the "flat top" WC till I saw one at Fred Wilke's.
I do not know for certain but believe that the wide front end was an option on the "flat top" WC.
Remember the W in WC stands for the tractor name.  The C stands for Cultivation unit which - at the time called for a narrow front.
I cannot help you with the 17" wheels.  Fred is the expert there.
Good Luck!
Bill Long
