Tractor "quiz" pg 4 |
Post Reply ![]() |
Mikez ![]() Orange Level Access ![]() ![]() Joined: 16 Jan 2013 Location: Usa Points: 8731 |
![]() ![]() ![]() ![]() ![]() Posted: 24 Apr 2017 at 11:02pm |
Ok last page of the tractor quiz.
19. In the WD-45 power created engine with 6.5 to 1 compression ratio: ( ) a. Only premium fuel may be used. ( ) b. Premium fuel performance is obtained on regular gasoline. ( ) c. Less horsepower is obtained on regular gasoline. 20. Maximum floatation on tractor drive wheels is obtained by: ( ) a. Increased tire size. ( ) b. Using correct air pressure. ( ) c. Removing liquid ballast. 21. The hand clutch on the CA tractor is a: ( ) a. Multiple plate wet type clutch. ( ) b. Single plate wet type clutch. ( ) c. Single plate dry type clutch. 22. The use of pressure radiators on model B, CA and WD-45 tractors: ( ) a. Raises the normal operating temperatures. ( ) b. makes engines run cooler. ( ) c. Eliminates the need of a water pump. 23. The term "power-crater" used in connection with the WD-45 engine refers to. ( ) a. The shape of the cylinder head. ( ) b. The shape of the valves. ( ) c. The shape of the piston head. 24. The automatic traction booster on the WD-45 and CA tractors: ( ) a. Positions an implement for working depth. ( ) b. Gives more traction with pull type implements. ( ) c. Uses some of the weight of mounted implements for traction. Ok guys last page of this quiz next week ill have one of he implements quiz. Enjoy. Edited by Mikez - 27 Apr 2017 at 9:34pm |
Nobody wants to play anymore
Lonn ![]() Orange Level ![]() ![]() Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29817 |
19 = b
20 = b 21 = c 22 = a 23 = c 24 = c There, I've hidden my answers Edited by Lonn - 28 Apr 2017 at 6:05am |
Wink I am a Russian Bot |
Ted J ![]() Orange Level ![]() ![]() Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18943 |
We want the youngsters to give some answers.
It's no fun if those of us "Golden Oldies" give the answers right away.... I'll give em a couple more days to see what happens. |
SURE!! Lonn types faster than me...
JarrodACFan ![]() Orange Level ![]() ![]() Joined: 24 Jan 2012 Location: Delaware Co. IN Points: 732 |
Here's my best guess:
19: B 20: B 21: C 22: A 23: C 24: C |
1956 WD45 Narrow Front Factory Power Steering, 1953 WD Wide Front
Allis Express in Muncie, IN |
Here you go.
19. B. 20. B. 21. C. 22. A. 23. C. 24. C. |
The guy that worked for my grandfather took this test in January 29/1957.
And got a 92% on it. |
I got them right
Post Reply ![]() |
