Early WC engine block question.
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Topic: Early WC engine block question.
    Posted: 24 Apr 2017 at 9:06am
I'm working on a 1937 WC with the 201 block and it only has the larger studs around the cylinders and not the 3 smaller studs on the lifter side of the engine block. There are no holes in the block for the studs it's just a flat casting with the push rods and water jacket openings. Was this a early 201 thing or what? It has a 3 inch head with holes for the extra studs. I'm guessing it's a later head though.
45 turboa- View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote 45 turboa- Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2017 at 11:05am
Early wc didn't have the three studs.
turbocharged
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2017 at 12:05pm
Thank you, should there be any concern with using the later head that has the holes?
