Snap coupler question
pa allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pa allis Quote  Post ReplyReply Direct Link To This Post Topic: Snap coupler question
    Posted: 24 Apr 2017 at 2:23am
I've been plowing in rocky soil, when I hit larger rocks the snap coupler pops open is this normal or is there something I should be doing differently?
corbinstein View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote corbinstein Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2017 at 6:18am
Safety question:
Do you have a chain around the snap coupler to keep the implement off the seat?
Can't answer your question however. spring maybe?
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2017 at 6:27am
what do you mean "pops open" the plow comes unhooked? Do you mean the hand clutch trips and the tractor stops?
The plow should never come unhooked unless part of the snap coupler system is wore out.
Some tractors had a throwout that would trip the hand clutch and stop the tractor if you hit a rock.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2017 at 7:24am
Does your tractor have one of these connected to the power director ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote pa allis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2017 at 8:05am
One of the two lift arm latches would snap open unhooking one side of the plow lift arm depending on the location of the rock. Never does the plow become unhooked from the bottom bell. No the tractor does not have the mechanism to release the hand clutch. After awhile I knew the sound of the coupler snapping open and I can stop the tractor and reset the arm latch without having to leave the seat,the plow never came up to be a safety issue.
Post Options Post Options   Thanks (0) Thanks(0)   Quote pa allis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2017 at 8:08am
No,there is no mechanism to the power director
Edited by pa allis - 24 Apr 2017 at 8:09am
Post Options Post Options   Thanks (0) Thanks(0)   Quote pa allis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2017 at 8:13am
Thought this would show up under Pat's reply, sorry for the duplication of my reply. Maybe some day I'll figure out how all this computer stuff works
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2017 at 8:49am
So basically what's happening is that the plow hits a rock which causes the plow to jump up. When the plow jumps up the lift link on the plow pushes the lift latch open and the lift link on the plow pops out and is disconnected.
If I understand this correctly, the lift latch is working as designed. The only thing that mit help is replacing the springs as they may have lost some tension.
Thanks & God Bless
Dennis
JimIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimIA Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2017 at 9:05am
As usual Dennis is correct. Springs are available from AGCO and Matt Scott sells rebuild kits as well.
Jim
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2017 at 9:07am
I agree with Dennis. Maybe annoying, but sounds normal. The idea is that if the snap coupler comes unhook, the releases will pop open, keeping the tongue from digging into the ground and flipping the plow up on the operator.
Post Options Post Options   Thanks (0) Thanks(0)   Quote pa allis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2017 at 9:17am
Thanks everyone for your support. I thought that may have been the answer, but I didn't want to keep using it that way if it could be corrected. So I 'll keep removing rocks, replace the springs and keep an eye on the latches as I go . Thanks again.    Eric
Edited by pa allis - 24 Apr 2017 at 9:18am
