The Old Man is Slipping
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Topic: The Old Man is Slipping
    Posted: 23 Apr 2017 at 4:55pm
Saturday I was mowing with the C that has the Woods mower under it. The Clutch seemed to have a funny sound when it engaged.  Kind of a snapping. When I was about as far away from the house as I could be the racket started and it wouldn't pull itself. I managed to get to the house without a walker and took the Farmall C back and drug it up. By the time I got it into position with the lift over the engine then spent two hours looking for my lift bracket. I gave up and an hour later I had another one to use and loose. By the time I took care of horses it was close to dark.
Told Dixie that I had a new clutch and pressure plate in the shed and in two hours I would have it repaired. Ya right! Once up on a time! The rear seal was leaking a bit and I had also bought a speedy sleeve some time in the past which I had seen a coupla days ago.
Five hours later I had the lip seal in and the new clutch and pressure plate all installed and the tractor started ready to mow. Let the clutch out and it snapped like it had. I drove it a few feet and put it in reverse and backed it up hearing the snap every time. Put it in low, engaged the power take off and went about six feet and it stopped pulling itself with all the racket it had when I thought it was the clutch.  Now it has to be the drive shaft coupling at the transmission.  I have a couple good drive shafts but this time I have to remove the Woods mower first to split it at the transmission.
The old clutch didn't look like it was bad enough to cause a problem. I put the transmission in gear and put lots of torque on the  drive shaft while I had it split and it held fine. I tried to pull the drive shaft forward and it wouldn't move. I had a cotter key in it when I put it together so I am not sure what I will find.
I was able to do most to the clutch work from stools and walker seat. Not sure how the back side will work out.
Edited by Dick L - 23 Apr 2017 at 4:56pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2017 at 5:08pm
Dick that's a lot of HARD WORK for a guy your age...Never heard of the shaft going bad. Clutch was a good guess !!   Don't work too hard. Plenty of breaks and rest... Got a  grandkid or local kid that needs to learn the ropes ???
Edited by steve(ill) - 23 Apr 2017 at 5:10pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2017 at 5:47pm
YEAH....I DON'T wanna hear that a tractor fell on you! or any part of a tractor! i'm with Steve on finding a helper! hows them sweet babies doing? haven't seen any pics for awhile
Hubnut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2017 at 6:12pm
You're quite an amazing man!  I got tired just THINKING about the work you did!  Best to you.
Steve
1940 B "Lucy"
1941 B w/ Woods L59 "Flavia"
1942 B w/ finish mower "Dick"
1941 C w/ 3-point "Maggie"
1947 C SFW w/ L306 "Trixie"
1972 314H
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2017 at 6:35pm
Aint no tractor gonna fall on this old man. No short cuts no matter how slow I is. I didn't took pictures even though I thought about it at one point. I had the jack stands under the drawbar with the rear tires off the ground slightly with the third jack stand under the knob under the torque tube. Solid as a rock. Engine held up slightly off the ground with the three ton engine lift.
With the mower pulled out from under the tractor I will have the same three point jack stand deal with one under the front of the transmission rather than up by the engine under the torque tube. The engine will be lifting at the back of the engine next to the gas tank. This will be a balancing point to pull the front away from the transmission from above.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2017 at 6:42pm
I have five mares due. Two real soon.  I bought a large person electric wheelchair so Dixie can get out to take pictures. I have three Great Grand daughters that are coming over to play with the horses when their mother can bring them, on nice days. She has taken some pictures and posted them on facebook. We will be getting more.
Jacob (WI,ND) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jacob (WI,ND) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2017 at 8:10pm
Yeah Dick, sounds like you've been busy!  Don't over do it, but glad to hear you have been  out in the garage working on something.  Keeps you young!
I'm curious to find out what the problem ends up being.  Take some pictures if it ends up being something interesting!
Jacob Swanson
1920 6-12; 1925,1926 20-35 longfenders; 1925,1926 15-25's; 1927,1929 20-35 shortfenders; C; B's; IB; WC's; WD; WD45
