Corporate orange paint
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Topic: Corporate orange paint
    Posted: 21 Apr 2017 at 9:13am
I am having the hood re-painted on my 9755 Agco Allis, and the guy at the body shop told me to just get the paint for it from Agco dealer (Butler Equipment), and he'd shoot it on for me. For some reason, I was always under the impression that Agco Allis tractors had a different shade of orange on them than the last of the genuine Allis Chalmers tractors that rolled off the line. But the parts man at Butler said that corporate orange is what it called for, and I know that that is what the last Allis Chalmers tractors had on them, also. Is this correct? It really does piss me off, though, that this tractor, being less than 20 years old, should need the hood re-painted. What did they use for paint.......? Water with a little food coloring in it? Thanks, Darrel
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2017 at 10:24am
Go look at an IH 88 series. They turned pinkish or purplish shortly after leaving the factory.
Wink
I am a Russian Bot
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2017 at 10:59am
they will never replace lead base paint with any thing that will last and be scratch resistant again, and if your kids are dumb enough to eat paint ...
ryan(IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryan(IN) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2017 at 11:02am
The 9000 and Dt agco tractors were corporate orange. A lot of new tractors fade and look at the cabs of a factory paint 8000 series they are all faded but the hood is not. (Well not as much. Haha.)
ryan
1984 8070 FWA,1979 7060,1975 7040,1971 190,1960 D-17D,1957 D-14, 196? D-19G, 1975 5040,1971? 160,1994 R62
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2017 at 1:59pm
so if the first go around faded what makes one think that the second one won't.  I would make sure that stuff from AGCO is not the same as other low grade enamels that look sharp when first put on.
I would go with a single stage urethane with hardener from an auto paint supplier.
WALLACE220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WALLACE220 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2017 at 4:08pm
Clear coat over the corporate orange. It will help.
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2017 at 7:00pm
x2
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryan(IN) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2017 at 7:06pm
Plus from factory they probably put the thinnest coat of paint they can on it.
ryan
Toscani NE SD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Toscani NE SD Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2017 at 7:34pm
no matter what paint you use its going to look different than the rest of the tractor just because of fading so you will probably end up painting the whole thing
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2017 at 2:37am
could make it last longer if stored out of the sun when not in use! (poke,poke,poke)
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2017 at 5:38am
I lot of the fading is a result of the EPA restricting emissions from some types of paints. Automotive manufacturers were forced to go to water based paints. The results can be seen in peeling paint on late 80's an early 90's cars.
A good automotive acrylic enamel with hardener will hold up well also.
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2017 at 8:35am
The hood is the only thing painted orange on this tractor. The rest of the orange stuff? (Fenders and roof top) are orange plastic. Some armour all, or something of that nature should bring back the shine in those pieces. Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2017 at 8:36am
that poker is goin to backfire on you some day, and poke a hole in your gullet. Lol Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2017 at 9:20am
can also try "color back"
or sum "Ajax" dissolved in warm water.
This page was generated in 0.081 seconds.
