8050 will move in reverse but stalls in foward
OGF HAY & GRAIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OGF HAY & GRAIN Quote  Post ReplyReply Direct Link To This Post Topic: 8050 will move in reverse but stalls in foward
    Posted: 20 Apr 2017 at 10:15pm
My 8050 has worked good up until last week and i backed up to a disk got hooked up and it wouldnt move in any of the foward gears its a ps trans with mfwd. It never has acted up and it full of fluid. Any suggestions on what to do to fix it
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2017 at 10:18pm
Welcome to forum. There's a bunch of good guys on here that I'm sure will help you out
Sagefarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sagefarmer Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2017 at 10:22pm
I cant help you either, but I will be following this. I was hoping to pick up another powershift for cultivating. Had good luck with an 8070
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2017 at 10:26pm
I would pull valve body off and check for stuck plungers. Usually caused by something coming apart. Might get lucky.      MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2017 at 7:47am
If you are lucky, don't start the engine just yet. Shift the lever from Reverse to 6th and back again, SEVERAL TIMES. Then, start the engine and see if it fixed itself. I've had this work a couple of times when a piece of debris got jammed in the valve plunger and with the valve cooled down overnite, was able to get things working again by this method.
Post Options Post Options   Thanks (0) Thanks(0)   Quote OGF HAY & GRAIN Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2017 at 8:36am
I tryed the shifting it back and forth it didnt seem to do anything i did figure out it will move in 5th an 6th gear but none of the low gears it just stalls out. If you guys know any more tricks ill try em i really dont want to tear this one down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2017 at 7:50pm
You now remove the power shift valve (behind the batteries)and make sure there aren't any stuck plungers or linkage/rack problems. No problem in the valve means the transmission has a problem internally.
This page was generated in 0.060 seconds.
