Allis Chalmers 33 Corn Picker Help
jpessek View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jpessek Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers 33 Corn Picker Help
    Posted: 19 Apr 2017 at 7:39am
My brother and I are going to pick up a 33 corn picker tomorrow, does anyone have some pictures of the brackets that go on the tractor for it?  We want to make sure we find everything.
www.allischalmersarchive.com
Your Source Of Free Vintage Allis Chalmers Brochures Available For Downloading
Robert Musgrave View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robert Musgrave Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2017 at 12:23pm
No pictures, but IIRC, there are brackets that hang from the rear drop axles, and brackets that hang from the frame rails, step pulley w/ V-belt drive and notched lever, mud scraper on the front tires, a window screen-type affair for the radiator, the engine side panels, and a small screen that goes over the air cleaner inlet.  There may be more.  R. Musgrave
Bull View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bull Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2017 at 1:19pm
Also brackets that mount to fender mountings on the axles to support the elevator. Don't forget the front half of the PTO shaft.
WD45 Diesel, RC,CA,IB, B, G, 616, Early B-10, D-10, Terra Tiger, 95G spreader, SC blade
Roger Mn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roger Mn Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2017 at 6:19pm
also replace glass sediment bowl with a metal one
DON G View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote DON G Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2017 at 8:13am
I think we have the rear mounting brackets also the piece of tin for under the radiator and steel gas bowl if able to locate.
grinder220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2017 at 9:35am
There's a different cylinder bracket for the right side used to raise and lower the picker, I'm sure I have an extra laying around if you need one. Also on the left side there's a bracket that holds the other cylinder up out of the way which I need but haven't found one yet.
