overcharging alternator
BKarpel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BKarpel Quote  Post ReplyReply Direct Link To This Post Topic: overcharging alternator
    Posted: 18 Apr 2017 at 5:08pm
We have a 9170 Deutz Allis that we have been fighting charging problems for a few years. All of this started after the cab was pulled off to fix the rear end. The problem is that it charges around 14 and jumps to 16 and maxes the gauge out and jumps around. It cooks out batteries. When running at night the lights go bright and dim. The dealer is at a lost and doesn't know what to do. The tractor was is there this winter when it quit charging. A wire under the dash was burnt off. I was driving it there when the cab filled with smoke and it started charging. They have replaced the alternator about 4 times, key switch, ac blower, ac switch, batteries, cables, wire from key to alternator, pulleys, belts. They where able to get the alternator to start charging after the tractor is running and not rev to 1500 the last time but nothing else is right. We ran 80 acres since then and the batteries were bone dry and water ran out the bottoms when we filled them. We replaced them last fall. The only thing powered by batteries is a fuel pump, ac, gps, tool bar monitor, radio. We dont run much at night. The alternator has a 3 wire pigtail and a post for the battery cable. Can you explain the pigtail wires. I think one goes to the tach and one gets power from the key. The delaer was out today and they didnt find anything. We installed 2 new batteries and keep going!  Im open for any help. Thanks Brandon
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2017 at 5:58pm
Hate to say this, but I bet it's a simple wire mash or connection somewhere,,, just my opinion
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2017 at 7:39pm
I've found in cases like this that it is in the grounds. Make sure of the ground from the batt. to frame, or however it is grounded. Run a ground from the ground post on the alt. to engine. Also run another ground from the cab to the frame. Look for any loose connections. Check for any corroded or rusted connections, even the light switch. This may give you a place to start. Let us know how it turns out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2017 at 10:37pm
Doug and Leon are on the right track. You can not have too many ground wires. When cab is set back on, it is easy to mash a wire or leave a ground wire off.    MACK
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2017 at 4:25am
I have no idea of how that alternator is wired, but if it uses external sensing the sense wire could be intermittently shorting to the frame somewhere.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BKarpel Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2017 at 8:20am
Thanks for the suggestions. Dad was disking last night and the tractor stopped moving. Think something from the engine to the transmission came apart. Motor runs and the transmission shifts through all gears. Dealer will have to get it on a trailer and tear into it. Wont get it back till done with field work. Im thinking the cab will have to be pulled off again. The worse part is the tractors rear end was pulled apart in 2009 for bad brakes that pushed metal shavings throughout the rear end. Too bad we put a new cooling fan and all new tires on it. Now we are down a tractor and ground working equipment. Our 25 foot disk is to big for the 1586 IH to pull. Going to try to find a field cultivator or rent/ buy a tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2017 at 9:14pm
Sounds like it broke hub out of clutch.      MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2017 at 9:05am
Dam that's bad luck,, hope it's not too expensive
