Pull start a 180
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Topic: Pull start a 180
    Posted: 16 Apr 2017 at 9:43pm
Would it be possible to hook up hydraulic lines from a 175 to the PD on a 180 and then be able to pull start it? Just thinking out loud....
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2017 at 10:51pm
what's wrong with just fixing what's wrong with it? (poke,poke,poke)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2017 at 10:55pm
Hate to burn up a starter to see if it will run...nice thing about the mechanical power directors in the smaller tractors is you can always pull start them without a battery or with a bad starter. I have no idea if this one will even run. Previous owner tried belting it up from the pulley but evidently failed.
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2017 at 10:57pm
oh...I thought it was yours! sorry! offer him sum watermelons and bring home a project! maybe Les would let you park it in his garage?
wayneIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayneIA Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2017 at 1:29am
I may be wrong, but better to say something now than to wish to have later.  If I'm not mistaken the PD uses lower pressure oil and a 2000 PSI remote will probably blow the seals.  Like I said may be wrong but better to not try it and find out for sure than to cause more issues.
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2017 at 8:39am
I would like to know whole story on him belting it up .How it failed. If the engine turns over belting it should work ,I have done that many times on tractors with belt pulleys.
With it belted and it dose turn over , he should be able to trouble shoot it as to why it dose not run. Was he using a side flat belt pulley mounted to torque tube housing ?
Edited by Fred in Pa - 17 Apr 2017 at 8:45am
nonetheless ,still dead.
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2017 at 9:21am
Porta-power to pressurize the power director? I know they use one to release the brakes on Gehl skidsteers.
AC200Puller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC200Puller Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2017 at 9:24am
The Power Director only gets 195 to205 psi hooking it up to 2000 psi would be a bad idea.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2017 at 9:56am
I bought the tractor a couple of years ago and didn't ask the seller for the details. I think he took the starter off to get it rebuilt, and for some reason didn't get it back. Someone was messing with the transmission, also...covers were off. I bought it as a parts tractor, but would like to see if I could get the engine to run...hopefully just a fuel problem. Sounds like the easiest would be to borrow a belt from someone and get it turning over that way.
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2017 at 9:57am
Thanks, that is what I needed to know.
ALLIS EXPRESS!
This year:
This page was generated in 0.060 seconds.
