WHAT IS IT?
HVFDFIREFIGHTER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HVFDFIREFIGHTER Quote  Post ReplyReply Direct Link To This Post Topic: WHAT IS IT?
    Posted: 16 Apr 2017 at 5:22pm
Does anyone know what this part is?  I remember taking it off the left side (as sitting on tractor) floor board.  Can't remember how to put it back on or what it actually does. I might even have it put together wrong in this picture.  Any help would be appreciated.
chuck (WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chuck (WI) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2017 at 5:26pm
I think its a bracket that holds the hydrolic lines. What tractor was it on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HVFDFIREFIGHTER Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2017 at 7:55pm
Sorry, I should have mentioned, it is a D14.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2017 at 8:20pm
Yep.  That is the securing bracket for the return hydraulic line.  You do have it put together wrong.  L shaped piece comes down against line on one side and the U piece butts against it with the line in the middle.  Also should be a rubber piece to prevent vibration wearing the line down.
Post Options Post Options   Thanks (0) Thanks(0)   Quote chuck (WI) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2017 at 12:37am
That's what it is. Usually the rubber is brittle one falling apart and no good, so I just find a piece of rubber round tubing that fit's over the hydraulic pipe and cut it to fit, looks good and works like a charm.
