Got another issue with my N5
AC 426 power View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC 426 power Quote  Post ReplyReply Direct Link To This Post Topic: Got another issue with my N5
    Posted: 13 Apr 2017 at 8:00pm
Got the header to lower and all but I went to try and see if the bin unloader would turn on and nothing. You can hear the solenoid valve trying to activate but nothing turns on. The combine and head both turn on and work but will not unload, any ideas where to start looking?
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2017 at 8:16pm
I look for ground wire issues. Our troubles are on an M3. In their case when the thresher or header won't start, I can trace it to a bad ground. In the header when I activate the switch it would bump up. Once after fiddlin' with the ground and no fix, I went the fuse panel and wiggled the fuse to get it running. I don't know how the unloader works on the N5 but if it's clutch driven I'd start with that. HTH
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2017 at 10:04pm
There is a safety switch on swivel of auger. Check for current through that switch. Check for current at unloaded solenoid and master solenoid.        MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2017 at 11:01pm
a mouse chewed the wire on my unload switch
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC 426 power Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2017 at 11:19am
Ah I jumped the gun again and posted, yeah only was another lose wire
