Rough running B
Brighton boy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brighton boy Quote  Post ReplyReply Direct Link To This Post Topic: Rough running B
    Posted: 11 Apr 2017 at 7:09pm
I have 1938 B that is a hand crank in good condition and recently I have been having troubles with it running. It starts ok but when it gets hot it doesnt want to stay running.  Anybody have an idea on where I should start to look?
RLBPA1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RLBPA1 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2017 at 7:15pm
Running good cold but not hot is a sign of a coil problem in your magneto. If it's not been changed from the original coil I would start looking there. A bad coil will also make it difficult to start when hot.
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2017 at 9:48pm
You may get lucky and get it running right by replacing the condenser.
Take good care of my favorite
Good Luck!
Bill Long
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2017 at 7:35am
If those suggestions don't work you might check the valve adjustment.
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2017 at 9:21am
I would start with valves.  No cost fix.
This page was generated in 0.101 seconds.
