D 15 charging system
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: D 15 charging system
    Posted: 09 Apr 2017 at 7:44pm
Can a faulty ignition switch cause the system not to charge. It has generator and voltage regulator. Thanks Tracy
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2017 at 8:00pm
Not with a regulator and generator. Broken wires, bad regulator or generator can prevent charging. A very worn generator pulley will also limit charging by letting the fan belt slip.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2017 at 8:45pm
Gerald J.
Gerald, wasn't sure. I did notice a dead spot in switch while cranking today. Had to hold it just right. Thanks Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2017 at 9:06am
Tracy, gennie on SII I had done only lasted two years. "Rebuilds" don't seem to last as long these days. Shop touted sealed bearings were much better and I have yet to get it back to the ol' boy's shop. Thought I heard a "growl" one day brush cutting and it was noticeable by touch with a bare hand.
