WD-45 Wide Front
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Topic: WD-45 Wide Front
    Posted: 09 Apr 2017 at 5:43am
What are 4 bolt WD-45 wide front ends worth these days?
NICKMI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NICKMI Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2017 at 7:22am
350-650 depends on condition
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2017 at 9:31am
No answer, but a related question:  Why are the 4 bolt front axles so desirable?
littlemarv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2017 at 10:18am
Weren't four bolts made a little heavier for loader work?
The mechanic always wins.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2017 at 12:38pm
The axle itself was essentially the same. The front pivot plate retained with only three bolts had an issue of sometimes loosening up when heavy loads/abuse was inflicted on them. Four bolts was better.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2017 at 3:22pm
Four bolt fronts are much more desirable because. There are very few there bolt fronts that haven't been repaired. The three mounting bolts are fairly close together so any extra stress has leverage advantage over the four bolts. I've never seen a three bolt with a loader that hasn't had to be repaired and usually farmer reinforced. Hen I was looking for a wide front they usually went for over $500 and it's hard to verify the actual condition from a picture. I found a complete running tractor for $800. It was in better condition. Than the tractor I was working on so now I have a pair of them. I cringe every time I see a diesel with a three bolt . It was adaquet for a gas tractor that wasn't abused but far to week for a heavier diesel or a tractor with a loader.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2017 at 4:28pm
If anyone is interested, I have a very good 3 bolt for sale. No repairs on it and good and tight $300 (In northern NY state, very close to the Ontario - Quebec - NY border)
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2017 at 5:12pm
My 45 has a 3 bolt. On 2 of the holes the casting was broke out so the farmer fix was a make a big frame that wraps around the whole front and uses the 4 frame bolts on the side   It's very stong. I welder friend of mine repaired the 2 holes by welding a half nut in there but I still use the whole frame fix. It makes mounting the front stack weight a little difficult.
